4 Malfunctions! (Update)
Old Apr 11, 2002 | 09:09 PM
PetersE55's Avatar
2001 E55, Silver/Charcol
Just in case anyone wanted to know...
Two weeks ago I had a problem which caused BAS, ABS, ESP and defective bulb malfunctions. The dealer told me that is was a defective brake pedal switch and replaced it. The problem came back immediately. Next, I was told that it was a loose connection at the control module which was fixed. I got the car half way home and wouldn't you know it, the problem is back again, and this is after they had the car for two days!
Turning the wheel all the way to the left, then right doesn't even clear the problem anymore.
The dealer doesn't know about the 2nd failed attempt to repair this yet but they will be getting an earful tomorrow.
Old Apr 15, 2002 | 01:40 AM
KWiK's Avatar
2002 C230 : 2007 C230
Be sure to do the following:
1. Have your service writer enter the problem in your exact words.
2. Use the same words to describe the same problem.
3. Keep ALL copies of service records.
4. Make detailed notes of any conversations with dealer employees.
5. Allow the dealer to keep the car as long as necessary to diagnose the problem.
This will make your lemon law case much easier.
Old Apr 15, 2002 | 10:07 AM
JamE55's Avatar
Out Of Control!
Re: 4 Malfunctions! (Update)
HHHmmmm Interesting.
