Hunming noise at low speeds?
2001 E320, 2010 E350 Sedan, 2009 E350 Wagon, 2014 E350 Coupe, 2015 ML 350
Hi everyone!
Started getting a faint humming droaning noise low speeds. Most noticeable when coasting between 1000 and 2000 RPMs. Don't think it's a wheel bearing, and you can only hear it inside the car. Impossible to hear it with a window down. Seems to correspond with engine RPM as opposed to speed. Any ideas? Any way to check the tranny fluid on these cars?
Austin,
The sound the you describe just started in my S55. I am really is the speculate and investigate mode. i somewhat want to look at the idler pulleys next. let me know if you come upon anything.
Best Regards.
Tom
Best Regards.
Tom
Thanks for the suggestion Plutoe!
Tom, it actually turned out to be a bad tranny mount that was completely worn. Replaced the mount and noise went away. It was inexpensive at my probate mechanic, only $150 for parts and labor.
Hope that helps.
Hope that helps.
