w210 - static in one speaker - agw problem?
Old Dec 9, 2017 | 05:01 PM
rayratjp's Avatar
1998 E320
Hello, first post and I'm hoping to add value as well as I continue down my problem solving path.
Radio will turn on sometimes, but mostly I get static out of the drivers side front door. At first I thought it was a blown speaker, ordered "new" ones on eBay, same problem. I removed the fuse under the rear seat, kept it out for a few minutes and the radio worked fine. However, it returned to the static after I turned the car on and off again. From what I've researched it's an audio gateway problem, but I can't find one anywhere online nor can I can find any other solutions, anyone else with this problem? Thank you in advance!
Old Dec 10, 2017 | 03:33 AM
fabbrisd1's Avatar
A gaggle of MB's
Check the speaker wiring for fray point where it passes into the doorframe and also where it passes into the door..
