My transmission model number location
I have a 1995 E320 MB but I need to identify the transmission.
Is there a plate where I can find this elusive transmission model number?
Where is this plate? I would appreciate any help. Thanks
why get dirty? couldn't you run your VIN and get the same info, or am I missing something?
https://www.datamb.com/
https://mbworld.org/forums/vindecoder.php
https://www.vindecoderz.com/
http://carinfo.kiev.ua/cars/vin/mercedes/vin_check
MB Transmission # 722369 04 107833
Now that I have the part number 722369 04 107833, do I need to match all the digits to find another transmission or just the first 4 digits?
My transmission will NOT go into reverse after it warms up. When cold it will run in reverse but only for 30 minutes or so.
Thanks in advance.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
You need to match the following---722.369-----then from your serial number you will be able to determine whether the donor transmission is newer or older than yours.
