W210 with Vogtland & Koni
E320 2000 w/GPS
Guys,
Here we go, just finished installed with Koni sport adjustable and Vogtland Springs. Pad size: front #3 bump, rear #1 bump. I think the front is way too high, 3 finger gap. Rear 1 finger gap. Carlsson 2/6 18" wheels 235/40/18 front, 265/35/18
street with uphill slope.
Do you guys think I need adjustable camber?
uneven street level though with uphill
E320 2000 w/GPS
Car in the leveled garage floor
leveled garage
left front in leveled garage
left rear in leveled garage
Do you guys think front and back not equal level of wheel gaps, does it look funny?
E320 2000 w/GPS
rear view in the garage
Do you guys think I need adjustable camber arms?
If I would replace with #4 or 5 rear spring pad, do I still need adj. camber arms. may be it is better to purchase one, so will help out the uneven wear on the tires. what do yo guys think?
E320 2000 w/GPS
picture of spring & shock
here is the picture of Vogtland spring & Koni Adjustable shocks
rear mounting
#1 bump rear spring pad
Guys, please give me some suggestions on how to make the front wheel gaps and rear looks more even....
thanks.
rear mounting
thanks.
1 Post
'04 Silverado Z71 - sold all my Benzes and need another!
You really need to change the front pads to bring the front down IMHO. Your rear camber is not that bad but if you'd like to correct it, just order the rear camber arms from speedybenz as we prev. discussed. With the way your car sits right now I would use #1 pads in the front and that would level your car out nicely and get rid of that huge gap.
2002 C230 : 2007 C230
I would suggest putting #1 pads in the front and I don't think you need a camber kit for the rear.
So how is the ride? How do you have the Koni's set?
E320 2000 w/GPS
ride
I have my Koni's front set at soft, rear set at 50% (soft-firm). I think it was a little to harsh, becuase you can really feel all the bumps on the road. I think I'll go back change the rear ones to soft, since the spring is low, so hopefully shocks will compensate that.
Well, I'll get the #1 pads for the front from dealer hopfully will bring the car to the level. So for the rear higher pads aren't necessary?
thanks, guys!
thanks, guys!
1 Post
Re: ride
thanks, guys!
thanks, guys!
I agree! front pads to number one. what sizes were on before install? did you do this install yourself? i am leaning towards vogtland springs but havent heard to much feedback on them. are you impressed?
E320 2000 w/GPS
Overall, I liked the setup. just make sure you have the right pads. #1 pad all the way around.
E320 2000 w/GPS
We have them here also
yeah i think i will go with this set up. i heard autozone loans the spring compressor! give them a call not sure if they do in your area.
Re: We have them here also
Are you sure you want to use the spring compressor? I think dropping the lower controller arm is asier...
E320 2000 w/GPS
Re: Re: We have them here also
Originally posted by KWiK
Not with the proper spring compressor
That's nice KWik, I wish I can access with this type of spring compressor, it would really save a lot of time with this particular kind. This one would be easier than dropping the controller arms. I couldn't find anybody in town has that. All we have in town is the cheap kind you can rent with two clamps on both end with a hook, and cramped down.
98 W210 Advantgarde
Sorry for the late reply - been travelling.
Sexy looking springs and the drop is a vast improvement. But yes, I agree, some pad adjustment is definitely needed. You may also like to consider swapping the fronts with the back for a tilted look..
E320 2000 w/GPS
Diameter the same??
98 W210 Advantgarde
Wasn't sure actually, my bad......sloppy advice again
Oh, well, can't wait to see. Not sure if the #1 up front would be enough with this setup....the front looks real high:o
E320 2000 w/GPS
#3 rear pads
98 W210 Advantgarde
You don't have a lot of crap in the trunk like me do you? Mine looks low in the back (especially with the front fender arch is higher than the back) still but it is actually fairly level as you can see from my sig pic. I responded to your PM BTW.
E320 2000 w/GPS
98 W210 Advantgarde
#1 front, #4 rears.....still not enough for the front IMO...of course it is different with different springs and I dun think many have your setup to tell u what's optimal unfortunately.
what is the difference in amount of drop between eibach and vogtland. whitey your car looks alot lower .i thought vogtland slightly lower drop
98 W210 Advantgarde
If Vogtland's are meant to be lower, I seriously think the cars in Asia and Europe are set higher than the US versions (that's what I observed on the stock cars...but dunno if its true, or how but it seems that way).
