AMG wheel fit on 1997 E420?
they should fit but with proper planning. the front tire will need to be selected to ensure
that the outside profile does not rub against the wheel arch lip. if the car's suspension
was lowered, tire selection is even more critical. same for shocks. also, verify that the
lug openings were designed for the 12mm diameter bolt diameter and not the larger,
later model MB which uses 14mm ...and larger ball seat.
