need front camber kit
Old May 25, 2004 | 12:59 AM
topdeez's Avatar
2012 E350 4matic/97 e320 and 01 ml320
i received my rear camber arms from jeff...awsome...i desperately need a front camber kit for my 97 e.....the factor bolts dont do sh*t. i still got a 3.1 and 4.1 degrees of camber in front...anyone knows anyone who makes an adjustable upper control front camber arm???or a better bolts to at least get me to a 1 degree camber in front??? much thanks
rock
Old May 25, 2004 | 11:17 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Re: need front camber kit
rock
I've never heard of a camber arm for the front but that doesn't mean it's not made. Have you tried H&R because they make the front camber bolts for our cars. Maybe they can help...
Old May 25, 2004 | 05:00 PM
topdeez's Avatar
i called h&r and they do not have camber bolts for e class...they have for other cars...anywhere else?
Old May 27, 2004 | 07:00 PM
rob_fed's Avatar
W204 C300 2010
How many miles are on your car? Just a thought, if it is real high, maybe some bushings are worn out. I assume you have lowering springs, right? If so, were the front tires wearing properly at the stock height?
The other thought is how much lower is the car? Same thought here, if you are really low, then no camber kit will get you back.
Old Jun 8, 2004 | 09:31 PM
MastaBenz's Avatar
99 E430 Sport
Been reading up on this forum and found 1 post saying that there is 4 corrections bolts needed for the front. 2 camber and 2 caster. I'm just wondering if that is correct? or is it just 2 bolts?
Anyways I drive a 99 E430 Sport and planning on getting it dropped next tues. Have all the parts and ready to go.
Old Jun 8, 2004 | 10:13 PM
topdeez's Avatar
thats correct, 4 sets of camber bolt kits from the dealer...2 on each side of the lower control arms. not much adjustment thou. probably about 1 degree.....good for moderate lowering..good luck.... post pics
Old Jun 9, 2004 | 10:49 AM
MastaBenz's Avatar
99 E430 Sport
Hey thanks for the response.
Old Jun 10, 2004 | 11:00 PM
E43's Avatar
E43
2000 E430 Sport
You may want to check out the following sites:
http://www.k-mac.com.au/
and
http://www.mrp-engineering.com
I'm having the same problem with too much negative camber after I lowered my car. The inside of my front tires are wearing way too fast. I haven't tried these products yet, but they might be worth the money given how expensive my tires are. If anyone has any experience with these companies or products, please let me know.
Old Jun 14, 2004 | 06:08 PM
MastaBenz's Avatar
99 E430 Sport
Prices seem Steeep/w kmac....
My front is gettin dropped H&R 1.4/w #3 pads.....so I'm thinkin the correction bolt might do the trick for the front. The back prob gonna get adjustable camber arms.
