Diagnostic port wiring diagram
Subscribe
Jun 15, 2018 | 08:50 AM
Hi,
I've got an engine from Mercedes w210 e300d on my boat, unfortunatelly it does not have diagnostic port.
Can I connect an obd2 socket to ecu so I can use regular obd2 scanner? If so does anybody has a wiring diagram?
Reply 0
Jun 19, 2018 | 04:02 PM
the whole point with ODB is standardized pinouts
for the basic interrogation points. so this is a simple thing. however, for the more
customized, proprietary functions, you may need to investigate more to determine
their proprietary protocols used
https://www.autoenginuity.com/products/oe-level-coverage/mercedes-ei17/
https://www.autoenginuity.com/dloads/enhanced_mercedes_user_guide.pdf
I'm not speaking from experience based and your project's needs are unusual.
I would guess there are many more modules you'll need in addition to the naked
engine in order to set up a code compliant system
Reply 0
Subscribe
Currently Active Users (1)
