97 E420 MAS replacement? Source?
Everyone says how easy they are to replace on the E320 (six cyl) but I have an 8 cyl. I popped the intake cover off tonight and had a look-see. Not as easy as a 320 I think.
Any advice on 1) procedure, 2) good factory service manual, 3) source for the MAS part (hey, everyone says so-and-so has 'em cheap but they always seem to be $450 or so). The thing looks like its worth about twenty bucks...any good alternative sources or OEM parts available?
Oh, and for what it's worth too: if I unplug the neg battery cable, does that reset the CEL? Or do I need to actually have it de-programmed using a scanner? I have one that gave me the codes easy enough....but if neg cable trick works I'll just use that...can anyone confirm?
Also beaware that there are 2 types of MAS for your car. It all depends on your setup, yr, type. I would not suggest eBay for that reason (people tend to lie). The dealership charges $450 like you said and i think it's lifetime if im correct.
Good luck.
Hey all, after reading all about the P0170, P0173, P0507, P0455 OBDII codes (my car has them all) it seems I might need a new MAS. I have goofy idle (sometimes perfect, sometimes bounces, sometimes wants to accel at stop, etc). Am I on the right track here?h
http://www.startekinfo.com/StarTek/
Parts stop/Fast Lane on Mercedesshop.com has Great Prices for any MB Part..Also Tom Hanson At Caliber Mercedes can give you 15/20% off list on Most all MB parts
When You remove the Battery it will reset the CEL..But NOT Remove the stored code..That Must be done with a MB Star or other diag code reader
Try The Mercedes site for any Info that you may Need
Did you ever get your MBZ running correctly?
I bought a MAS sensor that is a genuine MBZ part that will work on the TDIs. I was having a problem with my E-300 DT, so tried installing it, and it works fine even though the manufacture and the models are different. I paid $100 for it from a MBZ dealer.
Very easy to change BTW!
HTHs
