97 e320 motor replacement
Old Aug 29, 2018 | 11:59 AM
rogozzo's Avatar
97 mercedes e320
Hi I have a 97 e320 and the Trans cooler from the radiator let coolant into transmission, now I'm replacing the transmission with a good used transmission and the TCU from a 97 e320 parts car, my question is will I have to have the trans or the TCU or both flashed or reprogrammed to the car, is there a certain procedure to follow, any help would be greatly appreciated, thanks
Old Aug 29, 2018 | 01:01 PM
rogozzo's Avatar
97 mercedes e320
Transmission
Originally Posted by Plutoe
Not if the part numbers are the same for the cars
if the part #'s are the same do I need to use TCU or just the transmission?
Old Aug 31, 2018 | 05:04 PM
rogozzo's Avatar
97 mercedes e320
So blutoes, the car was in limp mode when I removed the bad transmission, the donor trans was working fine when removed from donor car, once the donor trans is installed (same part #'s) in the car and ready to go will it be out of limp mode or go out of limp mode on it's own or will I have to have it done somewhere?
Old Sep 1, 2018 | 11:21 AM
rogozzo's Avatar
97 mercedes e320
You mean test and clear with a MB star C3 Scan tool or take it somewhere that can do that?
