The key is not moving inside the switch
Old Sep 7, 2018 | 04:00 PM
Muhannad hadid's Avatar
W210 elegance 1998
please i need help in thes issue, after I come back from my vacation ( one month) I reconnect the battery and the remote is working as regular .
But when i put the key in the switch I didn’t hear the click sound and its not moving as well , The gear stock also in the parking.... and the battery was in a good condition .
What i can do .
Help
Old Sep 7, 2018 | 04:16 PM
raymond g-'s Avatar
99 E320
what makes you say the battery is good? what does this mean in a measurable sense? please quantify.
my suggestion would be to charge up the battery and measure the voltage...both at rest, as well as under cranking load
in addition, provide the year of your car as well as the key design it uses. these are important details
Old Sep 9, 2018 | 10:42 AM
W210 elegance 1998
Im sorry because I didn’t mention the details,
its w210 E240 1998 elegance withe 6 cylinder,
i feel the battery is good because the lights is working well .
but I will try to change with a new battery , and i will inform if it’s work ,
thanks a lot....
Old Sep 10, 2018 | 01:00 AM
raymond g-'s Avatar
99 E320
no, you should never assume the health of the car battery based simply on the operation of a light.
you still need to identify the type of key you're using, please. post a photo
