key question
Old Oct 6, 2018 | 11:46 AM
slick willy's Avatar
1998 e320 sedan
key question
if i use the "tool" inside the key to open the door, the alarm sounds. if for some reason i do not have the key to turn it off, how can it be done ?
Old Oct 6, 2018 | 01:57 PM
fabbrisd1's Avatar
A gaggle of MB's
You have to start the car with the fob
Old Oct 7, 2018 | 11:43 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Only remote or knob in the ignition will deactivate the alarm.
I wonder why you open the door with blade?
I used the method when going skiing with service key and wife was playing on snow with main knob.
Service key is moisture-resistant and being smaller- easier to carry for sport activity, but bad part is activating the alarm with blade.
You can avoid it by locking the car with blade, when alarm is not high priority.
Old Oct 8, 2018 | 11:48 PM
raymond g-'s Avatar
99 E320
from my 1999 owner's manual, "The antitheft alarm is automatically armed or disarmed with the remote control or any of your vehicle's
mechanical keys by locking or unlocking the driver's door or the trunk."
I'm not sure how your 1998 would differ. if i lock the car using the Smartkey and then...using the slim metal blade key... unlock the driver's
door or unlock via the trunk, the alarm does not sound
Old Oct 9, 2018 | 12:20 PM
kajtek1's Avatar
MB keeps changing the designs between MY, so best is read the proper manual.
The trunk central locking got deleted at some year (I think with lifting W210) but those things can change even mid-year.
Old Oct 12, 2018 | 05:05 PM
1998 e320 sedan
only have one key. $240.00 for a replacement i found online. so i keep them separated so if something happens i can open up the door.
