Correct Trans Fluid - 2000 E430
Old Oct 28, 2018 | 09:49 AM
loden338's Avatar
2000 E430 W210
Can Pentosin ATF be used in this vehicle? Or do I need MB oem? I'm not going to flush it, just drain & replace filter. How many quarts?
Old Oct 28, 2018 | 11:31 AM
raymond g-'s Avatar
99 E320
OWNER'S manual
Fluids recommendation chart
Oil threads can be found using the SEARCH function you see towards the top of the topics index over on the right side.
i tried to attach a link but it doesn't stay live after a session or two, so you should try it yourself
Old Nov 3, 2018 | 01:42 PM
loden338's Avatar
2000 E430 W210
Thanks Raymond. Looks like Valvoline and Fuchs would be good as would OE. Appreciate your reply!
Old Nov 4, 2018 | 01:22 AM
fabbrisd1's Avatar
A gaggle of MB's
Suggestion - when servicing the tranny - it is GREAT preventative maintenance to replace the tranny adapter plug/connector for like $14
Amazon Amazon
