2 Questions from Newbie
The headliner, although in great condition is sagging above the rear seats, almost from the back of the mood roof to the rear window. Aside from completely removing what are the best methods to repair?
My Brake Lining wear indicator warning is on, how do I tell if its the front or back brakes?
Thanks for any help
Daren
brake pads...the last time, i just looked. the cutaway window allows one to view the pads. popping
off the wheel is a 1-2 minute job if you (or neighbor) has a floor jack. but perhaps someone else
will respond with tips on this
so if you spray or saturate in between the layer with adhesive as depicted, there may not be sufficient hard
surface to adhere to. if that happens you'll need to switch to plan B...a more comprehensive repair/replacement.
you are looking at a 20 yr old car with a history of poor headliner adhesion, after all
You can buy new material at Joana's . but gluing it on the car is very difficult, if not impossible.
For brake pads, pull the wheel as raymond says, or use android snake camera.
Here's a video posted by a MB member on a DIY W202 headliner replacement that may be helpful down the road, if you chose to go this route.
