96 e320 battery draw
Old Nov 5, 2018 | 09:57 PM
ls67ss's Avatar
mercedes s500,e320
hello my mercedes has a heavy draw on the battery i disconnected the ground put test light between post and cable it lights up and kinda has a pulse to it.i removed all fuses 1 by 1 under hood,left panel of driver and fuse block near battery i could not get the test light to go out i had all doors closed trunk closed hood closed and let it sit before testing.i am not sure what to check or direction to go i put my multi meter between neg cable and battery post it read 5v draw if the helps.any ideas apreciated thank you
Old Nov 6, 2018 | 01:37 AM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Are you testing for a parasitic draw this way?
Old Nov 6, 2018 | 08:31 PM
ls67ss's Avatar
mercedes s500,e320
thank you. i did not do it that way. i will try this way and let you know what i come up.thank you
