Car trunk open alone
Old Nov 20, 2018 | 04:14 AM
Netfenix's Avatar
E 290
Question Car trunk open alone
Hello,
first of all, apologies for my English.
Suddenly, my car trunk open himself when I open the car with the remote control or manually, and after I stop and I open any door(you know that when the car is on going the doors are closed).
Then, I need help to solve this issue.
Old Nov 20, 2018 | 12:42 PM
raymond g-'s Avatar
99 E320
my first thought would be that it is either a failing pump, or that water has leaked into the compartment
beneath the rear seat which houses car battery, PSE pump, fuses, relays. The compartment is the low
point in the body so if the roof or door or trunk drains water into the passenger compartment, gravity
might direct the water into that vulnerable area. either way, you may want to examine this area for
any indication of moisture. this is presuming you have an 1999-2002 E320
