coil replacement
Old Dec 1, 2018 | 09:04 AM
slick willy's Avatar
1998 e320 sedan
Wink coil replacement
just ordered 6 bosch coils for my 1998 e320. do i have to disconnect the battery if i am careful ? btw, i got them for $220.00 AT apw with coupon. a steal !
Old Dec 1, 2018 | 02:10 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
I always recommend to disconnect the battery (neg terminal). It's a personal choice.
Make sure to work on a cold engine. Dont want to burn yourself.
Old Dec 2, 2018 | 04:46 PM
fabbrisd1's Avatar
A gaggle of MB's
It's a straight forward job - as long as you put the correct cylinder wire back in the correct connect... sounds stupid but I have seen more than one afternoon DIY frack up.....
Know how to remove top cover without lising rubber stops.... T30 torx .. I use small wire clippers for zip-tie removal .. few decent replacement zip ties.....this decent video will be quite helpful..
