97 e320 cranks over but won't start
Car does not start. I have replaced the crank shaft postioner sensor and the cam shaft. Checked relays and fuel pressure please help... Codes that came up we're 0300-0302-0303-0301 but that was before it stoped starting. My lame boyfriend went under the car and said the bolts in the flex plate we're loose. 2 of them fell out. He said he tightened the others up and told me to start the car but since then it hasn't started
Did you scan for any saved codes?
MAF could also be the culprit. Clean with MAF cleaner first. check connections.
