Check Engine Electronics
Old Jun 19, 2004 | 07:08 PM
ssickler's Avatar
I have a "check engine electronics" warning, a "check engine" light as well as an intermitent flashing low fuel gauge light. Has any one experienced these symptoms? Any sugestions? It's a 1997 E420
Scott
Old Jun 20, 2004 | 12:14 PM
E-Klasse's Avatar
W205 C300
Have you checked to see if your gas cap is on tight? Have the codes read to see what is setting the Check Engine Light on. If you do not notice any performance issues, then you can reset the codes and see if it comes back after a few drive cycles. You may just find that the gas cap was not on tight or needs to be replaced. The code may reset after the condition goes away or after you drive for 50 miles or more. I would read the codes first of all to see what turned on the CE light and then reset it by disconnecting the battery at the Negative Battery disconnect panel in the footwell on the rear passenger side.
Old Jun 21, 2004 | 06:01 PM
ssickler's Avatar
How do I reset the codes?
Old Jun 21, 2004 | 07:11 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Remove the battery ground cable for 15 min/Use a Scan tool/Or The Dealer with the $Star$
Old Jun 21, 2004 | 10:33 PM
ssickler's Avatar
All of a sudden it went off by itself! I hope it stays off. I can only assume it was the gas cap?!?!
Old Jun 21, 2004 | 10:36 PM
ssickler's Avatar
Hey where did you get your radio/cd player for the '96 e-calss you show? Will it interface wit a cd changer?
Old Jun 22, 2004 | 01:06 AM
E-Klasse's Avatar
W205 C300
Are you talking about this?
It is the Audio 10 CD. It will interface with the optical CD players found in the 99+ models. The CDC button sets it to control the CD Changer. You can get them on the German version of ebay www.ebay.de because they were only sold in Europe. A lot of people are installing navigation systems or COMAND and selling off the indash CD players.
