2001 E320 W210 Stuck in Park
Old Jan 25, 2019 | 11:38 AM
RonT7's Avatar
2001 E320
Please forgive me if I've missed a previous thread on this model. However, my E320 is stuck in park and I must use the manual release to shift it out of park. The shifter box appears to be all electronic and I'm not sure if there is anything "repairable" inside, like the older shifters. Am I correct on this assessment and, does anyone have experience with this issue on the same model? Brake lights are working, so the brake switch is not expected to be faulty. Any help is appreciated, and again, sorry if this is a repeat, I did search.
Old Jan 25, 2019 | 02:38 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
There are *two* switches in the brake light switch. The one for the brake lights could be working and the other not working. The swap is only 10-15 minutes. Start easy and then work up in difficulty of troubleshooting. There is a solenoid in the center shift module that fails on occasion but, again, start with the easy items first.
DIY here: https://www.benzworld.org/forums/w21...h-r-r-diy.html
Troubleshooting techniques here:
http://www.mercedesmedic.com/mercede...er-stuck-park/
Old Jan 25, 2019 | 03:11 PM
RonT7's Avatar
2001 E320
Many thanks for your reply, insight and resources!
Old Feb 19, 2019 | 07:55 PM
Change78's Avatar
2003 clk500 2005 cl55
make sure your bulbs are seated in connector properly also had same problem
Old Sep 1, 2019 | 11:41 AM
RonT7's Avatar
2001 E320
UPDATE:
Replaced shifter - Still will not crank
Turned key to on, jumped starter relay - engine cranked and started
With engine running, shifter will not shift out of P without pressing manual release button.
Once engine was turned off, received "2 MALFUNCTIONS" notification: BAS and ABS warnings
Read ODB II 3 codes after start: P0120, P0600 & P0705
Assuming:
P0600 = Serial Communication Link Malfunction
P0705 = Transmission Range Sensor Circuit malfunction (PRNDL Input) <- Culprit?
P0120 = Throttle position sensor
Codes were read with Innova 3020b
Did I mention this car is for sale...
