E320 vs. ML320 -- what's the difference?
Old Apr 23, 2002 | 04:50 PM
Ducati748Girl's Avatar
'01 Silver E320 Sport
Question E320 vs. ML320 -- what's the difference?
What's the biggest difference in the drive train that makes the E-series *not* recommended for towing, while the ML-series has a towing capacity of 5000 lbs?
* suspension?
* transmission?
* stopping power?
- ML weighs over 1000 lbs more
- E has more HP and torque
Thanks in advance for your help.
Old Apr 23, 2002 | 05:04 PM
ryson's Avatar
2014 E350, 2008 C300 Sport
Although I can't comment on the drivetrain, another consideration in towing capacity is the structure of the frame itself. If the car frame isn't designed to handle towing loads, you could be asking for trouble. The car may have the same drive train, HP and torque but if the steel reinforcement configuration isn't designed properly to distribute the loads, it could cause some serious damage during towing.
Old Apr 23, 2002 | 06:10 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
ML is a body on frame vehicle, E is a unibody. Besides, gear ratios, cooling system and trans are different on the ML
Old Apr 23, 2002 | 06:22 PM
ryson's Avatar
In that case, it's definitely not recommended to tow on an E class. You're basically pulling your trailer with the body of the car (instead of your typical body frame). That will eventually throw everything off kilter because everything is basically one whole unit. You pull one part and it will drag everything else with it.
Old Apr 24, 2002 | 05:09 PM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
hey, put some pics of ur ducati748 . what color do u have it in?
Old Apr 25, 2002 | 10:28 AM
My Duc
I have a yellow one.
You can see pics of both of my bikes on my site...
http://home.pacbell.net/lmbirch/bikes.html
And more pics of the Duc at...
http://home.pacbell.net/lmbirch/yloduck1.jpg
http://home.pacbell.net/lmbirch/yloduck2.jpg
http://home.pacbell.net/lmbirch/yloduck3.jpg
Old Apr 25, 2002 | 12:27 PM
steve s's Avatar
nice, yellow, best looking color for ducati . how much did u get it for?
Old Apr 25, 2002 | 01:58 PM
$12k.
