instrument cluster sometimes works
Old Feb 23, 2019 | 08:49 PM
ls67ss's Avatar
mercedes s500,e320
i have a 96 e320 and sometimes the instrument cluster works and others it does not.and i mean nothing works no gauges or lights .i have purchased 2 clusters off ebay both were defective in other ways but the last one was working sometimes like my original wich makes me think it might be something besides the instrument cluster.if anyone has come across this and can maybe point me in the right direction that would be appreciated thank you
Old Feb 24, 2019 | 12:15 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Clarify please, the entire cluster or just portions of it?
Sounds like an intermittent short somewhere.
Do the simple things first: pull all the relays and fuses one at a time (front and back fuse box), and used a small wire brush on a dremel tool to clean up the contacts and then test again after each cleaning. It could be as simple as this.
Old Feb 24, 2019 | 03:32 PM
ls67ss's Avatar
mercedes s500,e320
its the entire cluster it either works or it does not when you turn the car on.i have checked all fuses and all electrical wiggle tested while was on and working to try and get it not to i could not duplicate.alot of mb people state instrument cluster failure is common.just trying to figure it out
Old Mar 7, 2020 | 03:18 PM
Vernon Vaughan's Avatar
c200 kompressor coupe
On my c200 coupe 2003 the time feature in the cluster for setting the time is no longer there
any one know how to fix this please
