What code reader for a 1999 E320 w210
Old Mar 19, 2019 | 10:39 PM
Paulcomi's Avatar
2011 E550, 1999 E320
I want to read and clear codes for this car. I have an iCarsoft i980 but it jumps from w209 to w211 and won’t work for this car.
Old Mar 19, 2019 | 11:15 PM
raymond g-'s Avatar
99 E320
at one time, the i980 did not support the w210 models. i don't know if this has changed via updates.
Old Mar 19, 2019 | 11:21 PM
Paulcomi's Avatar
So what code readers or do it yourself folks using to work on these cars?
Old Mar 19, 2019 | 11:44 PM
raymond g-'s Avatar
99 E320
that all depends on the degree of codes people seek to read and erase. use the
right tool for the job. some DIY folks want as much control as available so will pay
top money. many varieties of diagnostic tools out there. oh, only basic coding is
available through the OBD2 port under the dash, but the round port in the engine
bay is the magic wand
http://www.mercedesmedic.com/best-ob...r-diagnostics/
http://www.mercedesmedic.com/mercede...-need-to-know/
Old Mar 20, 2019 | 02:37 PM
Paulcomi's Avatar
Got the Bosch one for $60 at O’Reilly. Cleared all my codes.
Old Mar 26, 2019 | 05:40 PM
charliev68's Avatar
2000 CLK430
Vident iLink400 with 38 pin connector. Works awesome!
Old Mar 27, 2019 | 05:41 AM
diesel man's Avatar
s210 220 cdi
hello,
I have MBcarsoft tester, I both old dell laptop with sirial(rs232) port, with windows XP, but still i need working copy of MBcarsoft 7.4. Cant find it on net... Can anyone help me, and send me the damn think!!!
Old Dec 1, 2020 | 09:18 AM
Zachary Stewart's Avatar
W210 E320, W211 E500, Two T1N Sprinters
Charliev68. So you have a 38 pin round physical adapter that goes to the code reader or a reader that has a 38 pin round plug to start with?
I need to check my 2002 E320's SRS light. Have you happened to do that with your iLink400?
I checked the compatibility list in excel format of the iLink400 and W210 isn't on it. But E-Class 210 it is on the list on the web site, but not much detail on needing the round adapter, or what it would be able to do.
Old Dec 1, 2020 | 05:09 PM
scotterikson's Avatar
01 clk430, 05 e500 4matic
Although it does have an OBD2 port, I believe that the port ONLY reads/clears engine codes (enough to satisfy mandates for sales). SRS, ESP, BAS etc must still be read through the 38 pin under the hood. I bought a used DAS in the classifieds here to read my older cars. Careful, plenty of sellers sell a conversion plug from OBD2 to 38 pin, but that doesn't mean a scanner will be able to read anything through the plug
