Help! Almost everything not working on my 2002 E320
Im thinking there must be a ground wire loose somewhere, but then I don't understand why it wouldn't all go out at once. I need a quick fix if anyone knows of one. My grandaughter who is 4, is having heart surgery tomorrow and I need to go down the hill to Loma Linda. I can't afford to take my car to mercedes right now. Anyone?
target rich environment consisting of fuses, relays, pneumatic systems equipment pump, battery etc.
The widespread symptoms you're describing seems to indicate that water may have entered that
compartment and shorted out critical components. The PSE pump controls door locks, fuel door,
trunk opening, rear seat headrests, antitheft. Simple check even if it is done to rule this out. Look
for dampness, rust, water line marks.
It is not sufficient to visually check the fuse. If water entered, each fuse must be pulled, cleaned
and checked using a continuity tester. Fuse clusters under the rear seat, on the left end of the
dash (must open door to access), and under the hood. There are other inline fuses etc but I
don't think those are suspect.
I don't understand the relevance of the key fob batteries being changed if the key has been stolen.
What key then are you using in order to operate the car?
You also need to systematically check for voltage in each key area and to each appliance you
identified as not working. You haven't reported the car battery voltage (at rest, as well as when
battery is under heavy load) so report back.
still be needed to have the pump know what features are on the car. hard to say without being there
