Central Locking Yellow vacuum line broken
The yellow line to the left rear door lock from the the PSE somehow broke in half inside the accordion that connects the door to the frame. Is there a way to splice the line? What is the part number for the yellow line? What is involved in pulling off the interior trim pieces to access that area between the body and the door?
Thanks in advance.
Thanks in advance.
https://www.benzworld.org/forums/w21...cal-order.html
scroll down to "parts diagrams". section 80 covers vacuum system
you can insert an inline fitting or you can buy a hose. the hose may get brittle and crack
when they age and/or exposed to the elements.
i'll need to dig around a little tomorrow as I only see my notes for under-dash-right-side removal
gmorgen1 (04-01-2019)
