battery draw any help appreciated
1996 e320 with ohm meter on 10a reads 0.23 between neg cable and battery.pulled every fuse cannot get it to drop.any ideas brand new battery goes dead in 2 days .please help thank you
When you say you "pulled every fuse....", did you do actually perform a parasitic test on each fuse?
What about the alarm system? These have known to cause battery draw issues.
no i pulled fuses 1 at a time seeing if amps dropped on meter to figure out what circuit is drawing in the vehicle.after i let sit aprox 1/2 hour to go into sleep mode.thank you for the help
