air flap actuator e200 kompressor
Old Jul 1, 2019 | 04:42 PM
Tiha4's Avatar
1997 E200 kompressor
hi guys i need help my car for the 180 horsepower it has it is really slow i found out the problem it is the air flap actuator located on the air filter box the air flap is opened horizontal and it does not close when im pushing the gas pedal it is stuck in that position but if the car is shot off i can push it with my fingers and i found some posts about resetting the air flap with someone pushing the flap while i give ignition it pushes the finger opens up but does not fix the issue what can i check or do to fix it ? the kompressor works if i put my hand on the hose or pipe that goes to the kompressor
