Help!! A/C Problem in hot, summer heat!
Thx!
Thx!
a 10min job
I Have seen SEVERAL of the sensors go bad ..with the same complaint as you have posted..
Also do a search on the W210 a/c controls for a read out ..Just to be sure..You will be able to read the values on the A/C control unit screen for the sensor It will be out of spec!
Strange that it's only 1 vent at a time. Does anyone have any ideas on this?
BTW, it's a '97 E420
Thanks in advance!
My car did the same thing today..
Its ok again now..
Did a diag test..
Evap sensor is "2" right now.. is that normal ?..
Pressure: 13bar
Right now i have several diag codes..
Evap sensor
Incar temop
heater core temp
Refrig temp
Refrig pressure
sun sensor
and
serious IF to Instrument cluster
Can these be old codes from before i got the A/C refilled ?
If yes..Is there any way to reset these codes ?
/kim
