Aux water cooling pump, working?
Old 07-28-2019, 02:15 PM
jbodentrader's Avatar
2000 E430
I have a 2000 E430and am having AC issues. no cooling on left side, while passenger side is fine. In my search for resolving this issue the aux water cooling pump was mentioned. I have literally never heard this pump operate and I have owned this car for about 6 years. It is my understanding the operation of this pump is more heat related than AC related. I have two questions, can the aux water pump be part of this problem, and if the pump isn't operating what are the consequences?
Old 07-29-2019, 09:21 AM
bbirdwell's Avatar
'99 and '05 E55 AMG
The auxiliary water pump is used to circulate hot coolant through the interior heater while the engine is turned off. Your issues sounds like a flapper valve is not opening/closing. First thing to check is to see if the vacuum line controlling the valves has broken and if not that, to check out the duo-valve. Photo shows both the duo-valve and the vacuum line in question. Benzworld and Pelican Parts have some good DIY in the W210 sections.
Old 08-02-2019, 02:52 PM
2000 E430
Bbirdwell, Hey, I know the stars at night are big and bright in your neighborhood and I greatly appreciate your reply. Yours was the only reply. After looking at Benzworld it became obvious this problem is not uncommon. Still only 1.
Old 08-02-2019, 06:59 PM
kajtek1's Avatar
Received 1,744 Likes on 1,391 Posts
1922 Ford Model T / no OBD
You can do full AC troubleshooting in about 90 seconds.
I posted links how to troubleshoot all over the forum, but if you have problem to find it, write it here.
Old 08-02-2019, 07:41 PM
fabbrisd1's Avatar
Received 1,100 Likes on 806 Posts
A gaggle of MB's
Do the diagnostic as Kai has posted - frankly I have seen low refrigerant cause more 1-side-hot-1-side-cold - frankly I have only seen 1-2 caused by the Duo Valve.
Start with the diagnostic and post the results and go from there - that's the best road..
Quick Reply: Aux water cooling pump, working?
