w210 722.6 gearbox shake problem
usually its 1 out of 3 gears (Park,Reverse and Neutral) yesterday it was Park that was shaking and neutral was the one that didnt shake.
also sometimes it doesnt upshift from first gear, have to either put it in a gear manually or let off the pedal and then hope it shifts.
i did order a dipstick for the gearbox that should arrive tomorrow, but how likely is low fluid level to be the cause of this? because the gearbox shifts smooth when it does what it has to do.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
The shaking isn't coming form the transmission unless all the bolts are loose, which is not probable---your issues are with the engine that can shake!
