2002 E320 Transmission Issues
Old Nov 7, 2019 | 12:01 PM
rtemple136's Avatar
2002 E320
So this is a bit of a long story. I am lost, and don't know what to do from here. I hate to junk the car, but I am getting close:
A month and a half ago, I bought a E320 on ebay, sight unseen from california. It was shipped to my house in Texas. The transmission hasnt worked right since I bought it, and the seller has been a jackass. Anyway, I replaced the conductor plate. That didnt help it. I broke down and took it to the dealer. they said it was a defective valve body. An inde shop ive used before with old germans transmissions took a look at it, took the valve body apart, cleaned some gunk out of it, and put it back in. And he replaced 2 defective solenoids. They also discovered out that the tcm in the car wasn't the correct one. Obviously the car had trouble before leaving the west coast, even though the seller denied it. My mechanic said there is a good chance that if I got the correct computer, it would shift again. Found one on ebay, and nothing. I get first gear when i start the car, then it shifts to second, then it is stuck in limp home mode. I can get 4th or 5th if i get up to speed, pop it into neutral, then back to drive. it will down shift back to second when i come to a stop. I tried to take it back to the first mercedes dealership to see about reflashing the new tcm, and they tried to tell me that you cant rebuild a valve body, and they are coded to the car. Its a chunk of aluminium with 6 solenoids. Im thinking about trying another mb dealership, but they want $350 to look at it. Any advice at this point would be handy
Old Nov 7, 2019 | 01:28 PM
rtemple136's Avatar
2002 E320
ok, I think I might have bought the wrong tcm. I bought on ebay a 032 545 23 32. Apparently there was also a 030 545 23 32. Is there someone on here with a 2002 E320 that would be nice enough to verify what tcm is in their car? I would be greatly appreciative
Old Nov 7, 2019 | 03:07 PM
rtemple136's Avatar
2002 E320
Originally Posted by Plutoe
Yep,post your VIN
WDBJF65J22B410182
