E430 crazy idle speed
Old Nov 7, 2019 | 08:17 PM
Kevs e430's Avatar
2001 E430
Hi i have 01 e430 it surged and trys to runaway i changed throttle body calibrated it good for a few days back to same.It gives codes 2032 m16/6r1 Throttle valve actual valve potenionmeter line mixed up and also code p202e throttle valve actuator line mixed up fault p0120 can someone help me with this ?Thanks!!
Old Nov 8, 2019 | 07:38 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Kevs e430,
Could you kindly post/ correct your issues in grammatically correct sentence order (with correct punctuation and capitalization) so that all members reading your post can comprehend what you are asking.
Not much to ask if you are looking for some assistance to resolve your issue.
Explain exactly what you did.
Old Nov 11, 2019 | 07:56 PM
Kevs e430's Avatar
2001 E430
Carzy idle speed
Hi i have a 2001e430 when i start it up it revs around 1200 rpms at one pointvit would not run I changed the throttle body i calibrated it The car ran for 6 days then went back to the same thing?Im using snap on solis edge scanner in data mode it does not seem to see the gas pedal ?I move the pedal but it does not show it on the scanner .It give codes 2032 for throttle valve potentiometet lines mixed up also esp electric stabilzer shows sometimes is screen is i keep clearing the codes sometimes it will start and idle normal around 800 rpms and drive fine.Can anyone help me with this problem? Thanks Kevin
