W
Mercedes E200 W210.235 722.6 transmission problem
Jump to LatestUnfollow1 - 4 of 4 Posts
W
W210 Wagon
Registered
1999 W210 Estate WDB210235 M111.942 722.615
Joined Jan 29, 2011
100 Posts Discussion Starter • #1 • 8 days ago
I have a Mercedes Estate Model E200, 5-Speed Automatic Transmission
Chassis WDB2102352A990050
Engine 111.942
Transmission 722615 01 719274
1) Able to shift from P to R by pressing brake pedal (normal).
2) Cannot shift from N to R if press brake pedal (Can shift from N to R if not pressing brake pedal).
3) Noise when shift from N to D.
4) Indicator on instrument cluster did not change when I shift gear.
5) No warning light.
Is it possible Limp mode after replace new battery?
Quote:
W
1 - 4 of 4 Posts
W
Joined Jan 29, 2011
Engine 111.942
No CEL does NOT mean you have no error codes saved.Originally Posted by W210 Wagon
W
W
W210 Wagon
Registered
Joined Jan 29, 2011
Engine 111.942
You still should scan. Post codes here, if any.
Thanks khomer2. Will scan and post code here.Originally Posted by khomer2
No CEL does NOT mean you have no error codes saved.You still should scan. Post codes here, if any.
