Misfire
Old Jan 23, 2020 | 08:57 AM
Ledbelly's Avatar
2002 E240 W210 Elegance. 2003 CLK320 W209 Avantgarde.
Misfire
Hi all,
I have a 2002 E240 W210 with 65000 miles on it and it has a misfire problem.
It runs really smoothly but has a slightly lumpy idle.
If I floor the throttle I get the check engine light and it throws a misfire code for either random multiple misfires, cylinder 3 or cylinder 5.
Once I get the CEL it does run on 5 cylinders but if I switch off and start back up it is fine.
I have cleaned the MAF sensor and tried changing coils ( I have some spares) but it makes no difference.
Any ideas out there?
Old Jan 23, 2020 | 10:48 AM
e350forme's Avatar
fleet
have you changed or looked at plugs? gap ok?
have you put in new ignition wires?
I have done all the basic trouble shooting for my car, and in the end, she still seems to have a "slightly lumpy" idle that I cant figure out!
Old Jan 23, 2020 | 01:00 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Originally Posted by Ledbelly
Hi all,
Scan and post your error codes. CEL came on - this means you have codes saved.
Old Jan 26, 2020 | 10:48 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
I wonder why changing the coils and not the spark plugs?
How many plugs per cylinder the engine has?
Old Jan 27, 2020 | 01:32 AM
fabbrisd1's Avatar
A gaggle of MB's
I would have the CAT's tested - the front cat tends to breakdown - throwing chunks into the rear cat - which cause blockage and restriction on acceleration.
Low mileage W210 are subject to this..
A. Rear cat blockage can cause this accleration/backup/CEL - rubber mallet - tap the rear cat and listen for that debris - you can cut rear cat out - empty the chunks - and reweld back in,
B. IR thermometer with your E running and up on a rack - exit temperature at back of cat "should be" much higher than entrance temp at front of cat
If by "lumpy idle" - you mean pulling towards a braked stop - the RPM starts to drop below normal idle - feels like engine "choking" - then catches itself and goes back above normal idle - then drops/catches itself again - then you need a replacement genuine Bosch MAF from a reputable source which in the UK is a issue who to trust (and pay). UK has all those cheapie China Maf's - cheap but junk really
If by "lumpy" idle you mean no "choking" - then you need to chase vacuum leak... by "age" plugs are due .. MB cables/coils rarely go out unless overheated - but swapping back and forth can identify a bad cable or coil,
Time for a fresh OE fuel filter too.... and clean up your tank with Stal-Marine 308 fuel stabilizer available from UK Amazon
Old Jan 31, 2020 | 02:35 AM
Ledbelly's Avatar
Thanks for all the replies. I finally got around to changing out the spark plugs and it is now fixed.
I have to say that the plug swap was nowhere near as bad a job as I had been led to believe.
Old Feb 12, 2020 | 08:14 AM
Ledbelly's Avatar
Oops! Spoke to soon. The plugs and leads have fixed the CEL/misfire issue and it runs beautifully and gas mileage is noticeably better but I still have a lumpy idle.
It's quite bad when cold and just noticeable when warm, in fact it almost disappears after a good run when thoroughly warmed up.
I tried the MAF sensor off my W209 (same part) but it made no difference.
Has anybody got any ideas? Vacuum leak maybe?
Old Feb 12, 2020 | 10:36 AM
kajtek1's Avatar
Run injector cleaner.
Than do few "Italian tuneups"
