sat nav installation
Old Jul 27, 2004 | 07:23 PM
mickyg's Avatar
98 300 turbodiesel
Hi,I am Installing a Pioneer sat nav unit into my 300td,but I am having problems finding the speedometer pulse sensing wire.Can anyone help me to identify this wire.
Mick
Old Jul 27, 2004 | 07:29 PM
miroj's Avatar
Mick
Isn't it in the doorsill - green-black on a blue connector the same as it always was ?
Old Jul 28, 2004 | 03:52 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
1) The W210 NEVER had a blue connector with a green/black wire...
2) he has a 98 300 listed in his profile...so guessing that that is the car in which he is installing his nav...
I would say: A connector pin position 1.
greetingz,
Old Jul 28, 2004 | 04:09 AM
miroj's Avatar
greetingz,
I looked in WIS and the wire is behind the instrument cluster.
" connect green lead to multiple connector / Hall sensor / Speed signal (X35/5) behind instrument cluster. "
Maybe that helps.
Old Jul 28, 2004 | 11:54 AM
mickyg's Avatar
98 300 turbodiesel
Question speed pickup
Thanks for the help,but which is connector A,or X35/5.
My vehicle is a right hand drive E300td 1998
Old Jul 28, 2004 | 01:11 PM
MBenzNL's Avatar
some slow@$$diesels
Maybe that helps.
Simply copying something out of WIS doesn't help much...nobody knows where to find X35/5...
AGAIN, I would say: A connector (bottom connector in the back of the radio...) pin position 1 (the number can be read of the connector)!
greetingz,
Old Jul 28, 2004 | 04:45 PM
mickyg's Avatar
98 300 turbodiesel
The only connectors I can find are the ISO connectors for the radio power & speakers.There is one other black plug but this has only got an earth wire to it.Looks like i will have to buy The Pioneer pulse generator
Old Jul 29, 2004 | 05:16 AM
MBenzNL's Avatar
some slow@$$diesels
the third and last time I write this down...A connector pin pos 1!!!
The ISOconnector is a combined A connector (bottom 8 pin positions) with power, ground, illumination, SPEEDPULSE, and some other features and B connector (top 8 pin positions with the speaker wiring)...
A connector pin position 1!!! No need to buy any pulse generator as your car already has a speedpulse AT THE RADIO.
greetingz,
Old Jul 29, 2004 | 05:25 AM
miroj's Avatar
I think you are making too much work for yourself. Why not take Steves advice and see if it works.
Old Jul 29, 2004 | 05:42 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I read somewhere on the internet that you can find the speed pulse on the A-connector pin position 1. See http://www.beckerautosound.com/1492.jpg and http://www.beckerautosound.com/1492.html ...
But truthfully, I think you should probably buy the Pioneer Pulse Generator. It would save everyone else a lot of trouble.
-s-
Old Jul 29, 2004 | 11:52 AM
mickyg's Avatar
98 300 turbodiesel
Thanks Steve,Tried it this morning and it works a treat.
Old Jul 29, 2004 | 08:32 PM
MBenzNL's Avatar
some slow@$$diesels
you're welcome...there was a moment I thought my spend input would have been wasted, but good to hear it worked out after all.
greetingz,
