Oil leaks
Old Aug 6, 2004 | 06:35 PM
Arnie's Avatar
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
Oil leaks
Hi everybody.
I currently own a 94 E320. In the next few months I want to get a '00-'02 E430. I had 3 different MBZ before. They all leaked oil from the timing cain cover and from under the cylinder head. On my current car I ended up replacing a head gasket and sealing the chain cover, which stopped all oil leaks. Did Mercedes finally fix the oil leaks problem or is it still there?
Arnie
Old Aug 6, 2004 | 06:44 PM
MBWorld1's Avatar
All the older M102, M103 & M104 engines are known to have oil leak problems.
Look for a 98 and higher models and you should be ok.
