Rough running
Old Aug 8, 2004 | 06:28 PM
Michael Pietrzy's Avatar
1997 E 420
Question Rough running
97 e 420 4.2 Engine was running great than this morning when i got on the x way started running rough like it wasn't running on all 8. CEL came on and
Eletronic senser came on. After cool down started fine but when warmed up same problem?
Old Aug 8, 2004 | 10:44 PM
F1Fan's Avatar
I had a similar issue in another car. When cold, everything would run fine. However once warmed up, it started to misfire. Found out that one of the ignition wires had deteriorated so there was not enough electrical current reaching the spark plug, which resulted in a misfire. The car felt horrible when it happened. Hope this helps. Might be a good idea to get the error code diagnosed first.
Old Aug 9, 2004 | 08:14 AM
MB Enthusiast's Avatar
1997 E 320 - 2000 S500
Check the plugs
I had the same problem and it was a spark plug. I replaced them all and the ingnition wires as well. The bosch plus model plugs were recommeneded and the Beru wire set.The car runs great now.
Old Aug 9, 2004 | 09:08 AM
1997 E 420
Going to get a code reader will go from there
let you know
thanks
Old Aug 10, 2004 | 09:45 AM
1997 E 420
Checked the spark plugs first and found water in 3 of the spark plug wells blew them out checked all plugs back together and running great again. Water must have gotten in when cleaning engine. Cleaned before never had problem, will have to get new seal for covers over plug covers
so Thanks Again for help :
Old Aug 10, 2004 | 10:04 AM
E-Klasse's Avatar
W205 C300
If you would have said that you washed it, I would have said to check for water in the spark plug wells. When I had my car detailed and they flooded my spark plug wells and did not blow the water out. It ran rough and the CEL came on for cyl. misfire. Glad to hear you solved it.
