rear brakes
Old Jul 29, 2020 | 07:15 PM
tharlos's Avatar
1994 e320
Unhappy rear brakes
Had some pulsing from the rear brakes. took off the pads and looked at the calipers and the rear left caliper had a piece broken off causing the inner pad to bind and wear down the pad and inside of the rotor. So, put new calipers and rotors and pads on the rear but could not get the rear brakes to bleed. Pulled the hard lines off the two rears as well as the line coming from the front and capped THAT line.Made two new hard lines in case they were bad, as they looked rough. When I pumped the brakes before I capped the line from the front fluid came out so I figured it wasnt blocked from that point forward. Put everything back together and cannot get any fluid out to the rear brakes when I am trying to bleed them. I am stumped and ready to blow this thing up. Anyone have any ideas. I am getting NO leaks on anything I worked on and/or replaced, nor any leaks anywhere else. I am at a loss.
Old Jul 29, 2020 | 07:20 PM
speedlimit's Avatar
Administrator Emeritus
Hi!
Let's try the E-Class (W210) forum for help. Good luck!
Bob
Old Jul 29, 2020 | 07:23 PM
speedlimit's Avatar
Hi,
Moving
Bob
