wheel fitment problems
Old Aug 14, 2004 | 09:48 AM
EShklovsky's Avatar
Exclamation wheel fitment problems
I have a 2000 E430 sportpackage I just bought a set of wheels on ebay that were promised they would fit, they are 18x8.5 in the front and 18x9.5 in the back. But the front inner lip of the wheels is rubbing against the metal axal cover, looks like the problem would be solved if the wheel was moved out 5 - 10 mm or so, is there a solution so that will allow these wheels to fit on my car? Please HELP I would appricate any feed back!!!
Old Aug 14, 2004 | 12:08 PM
zam2000's Avatar
S, GL, Escalade ESV, my shoes
Get a spacer. Make sure you get a good one. Also, since the car is hub centric, you may need as hub ring as well. This must be done by someone who know the job, otherwise, you may experience vibration at highspeed.
As reputable wheels shop should be able to fix this problem.
Old Aug 15, 2004 | 12:27 PM
EShklovsky's Avatar
Thank You
THank you, do you reccomend a particular size for the spacer I know they come in 3 - 10mm or so and what are the 2 parts I need?
Old Aug 15, 2004 | 12:34 PM
Whitey's Avatar
98 W210 Advantgarde
The the size of spacer really depends on the current offset of your wheels and what sort of fender alignment you want - "agressive" or "mild". I am currently on ET35 with 9.5", great fender alignment and no rubbing inside or out. The offset should be imprinted on the inside of the wheels.
Spacers that are hubcentric are one piece and fit straight into the slot of the OEM hubcentric ring in the wheel. You may need to remove the OEM ring that is attached to the OEM wheel (or sometimes stuck on the axle, depending on where it decides to attach itself). Another important thing to remember is you need the right length bolts - too long and you'll get rubbing on the handbrake assembly, too short and it'll be dangerous (if it holds the wheel at all).
Old Aug 15, 2004 | 06:43 PM
EShklovsky's Avatar
Size
What size do you reccomend for the front wheels for the spacers and the bolts?
Old Aug 15, 2004 | 11:33 PM
Whitey's Avatar
98 W210 Advantgarde
ET30-31 would be a good alignment for the 8.5" fronts (31 is what I have), again I need to know the current offset of the wheels in order to tell you what size spacer is needed to achive the offsets I have recommended.
As for the bolts, it depends on the design of the wheel, best is to check how much the bolts stick out at the back of the OEM wheel (with the OEM bolts) and get bolts that will give you the same or close number of threads with the spacer you get.
Old Aug 15, 2004 | 11:49 PM
EShklovsky's Avatar
Wheels
These are the wheels I got I am would you be able to know what offest they are from looking at them I think they are for a S-Class and tell me what spacing I need and bolt size?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Aug 15, 2004 | 11:54 PM
Whitey's Avatar
98 W210 Advantgarde
Man, those wheels came from an SL (according to the ad). I think that means your rears are in the range of ET40+ offsets, that why it not surprising you're rubbing on the inside. If they are real AMG's there should be offset measurements casted onto the insides of the spokes, (should say ET??). Best to read them, than for me to guess. However, don't mean to discourage but I warn that long bolts for spacers of 5mm+ are expensive and difficult to come by..........
Old Aug 16, 2004 | 12:12 PM
EShklovsky's Avatar
Rubbing
I am only rubbing the inside on the front wheels though, where is the best place to get them>
Old Aug 16, 2004 | 02:31 PM
Whitey's Avatar
98 W210 Advantgarde
take them off!....take one off
Old Sep 9, 2004 | 02:54 AM
legendary's Avatar
Veteran: Marine Corps
2008 CL550, 2018 E400 Coupe, 2019 AMG GLE43 Coupe, 1968 C10 Restomod
did you ever get this figured out?
What are the offsets on the wheels? At least the front??
