Att: Techs... A/C Problem
I have a 1997 E-320. The air conditioning is not working... The economy light stays on and can not be turned off. A mercedes tech told me that the refrigerant needs to be refilled and another tech told me the control unit is bad. One day i turned on my A/C and i heard a hissing noise. How can this problem be fixed? Can someone help me? What parts are needed?
I was worried about having to replace the evaporator (supposedly a big-time labor charge) but it turned out to be a <$60 plastic temperature sensor of some kind. My independent shop guy told me that this part is a somewhat common failure in the E class.
Luck.
Not a tech guru by any means...
Your problem is most likely a faulty evaporator temperature sensor. Have you run the diagnostic to check the codes and actual sensor values? Post all the codes and post sensor values #3, #4, #5, #7 & #8 with the engine & A/C switched on.
Here are the instructions to access the diagnostics:
http://www.continentalimports.com/ser_ic40142.html
Does it mean I have a bad evap temp sensor, where is this sensor located ?
The AC temp was set as 72 per instruction and car was park in side garage while I took this value
1 = 75
2 = 73
3 = 80
4 = 78
5 = 143
6 = 85
7 = 06
8 = 76
9 = 27
10 = 1.1
11 = 0.3
12 = 4.3
20 = 3.2
21 = 32
22 = 00
23 = 32
24 = 11.6
40 = 164
41 = 85
42 = 40
43 = 136
The system thinks your A/C temp is 143 degrees. It's blowing ambient air because the outside air temp is much cooler than 143!
The system ignores the evaporator temp sensor data for the first 10 minutes of operation. The fault is characterized by your A/C quitting 10 minutes after the ignition is switched on.
I believe the sensor is installed in the airflow behind the evaporator case. Not sure how to access it. Maybe someone else can help with this. I had a shop replace mine; labor was minimal.
Can some one point where to look for
Car is 1999 E320
Tan
1=76
2=75
3=75
4=67
5=73
6=152
7=06
8=82
9=31
I found #6 sensor is call ECT Sensor and the number seems high. What is ECT Sensor? And is this the problem? Any suggestion will be greatly appreciated.
John
#5 is your evaporator temp sensor. This should be in the 30s, not ambient. So, the car agrees with you that the air isn't cold.
#3 & #4 are the temps of your left & right sides respectively.#7 & #8 are your refrigerant pressure and temperature. #7 varies depending on how much compression is needed to cool your car. #8 always needs to be more than outside air temp (#2 = 75) to move heat from inside your car to the great outdoors. It is higher than the outside temp, so it looks like your A/C is working, but just barely.
You're probably low on refrigerant. Any hissing noises from the center vent? Is the passenger side center vent cooler than the driver side center vent? Oh, and the EC light is off, right?
John
Car is 1999 E320
Tan
John
You might also notice that your right side (#4) is quite a bit cooler than the left side (#3). When both sides are set to the same temp on the climate control, and the right side blows colder, this is symptomatic of low refrigerant.
John
Edit - I pulled the codes from my car. They look to be in Celcius.
1 40
2 28
3 33
4 33
5 57
6 65
7 03
8 37
9 05
10 4.5
11 2.1
12 4.0
20 0.0
21 00
22 00
23 00
24 11.4
40 71
41 34
42 72
43 152
Error codes
Eb1234 <--- Sun Sensor, how would this failing affect my AC and whats the part replacement cost?
E FF <---- No idea what this means.
John
01=123
02=141
03=116
04=116
05=154
06=200
07=E
08=130
09=27
i just hope i did not mess up thing i have not since this numbers here
