W210 Wheels
Old Sep 28, 2020 | 12:03 AM
1996w210's Avatar
1996 E320 Sedan
W210 Wheels
Hi. I’m hoping to upgrade the look of my 96 E320. I found a set of wheels from (I think) a newer S class. The size is 7.5X16 ET 46. Does anyone know if these will fit my car?
TIA!
Dan
Old Sep 29, 2020 | 01:30 AM
raymond g-'s Avatar
99 E320
yes / no - those are not the entire specs needed to confirm. chances are the lug spacing will be okay.
the devil in the details:
the offset is high and is about 8mm more than your stock wheels
the tire you put on will affect fitment (may scrape)
you may need something like a 10mm spacer
the lug bolt seat in the wheel may be larger since it is an S wheel. the w210 wheel uses smaller radius ball
Old Sep 29, 2020 | 03:23 PM
illest's Avatar
w210 AMG or S213
7.5 x 16 does not sound like much of an upgrade, the stock wheels are that same size but et 41
