W210 control arm
Old Sep 29, 2020 | 01:29 AM
Novruz Pasazade's Avatar
W210 2000
W210 control arm
Hello. i have w210. Can I replace what is shown in the photo with that of another car? I want to wear bigger and wider tires.
Old Sep 29, 2020 | 09:22 AM
speedlimit's Avatar
Administrator Emeritus
Hi and welcome!
Moving your question to the W210 forum, good luck!
Bob
Old Jan 31, 2025 | 09:53 PM
nelbur's Avatar
1997 E300D
That is the upper ball joint. I think the answer to your question is no. You might be able to use a wheel spacer or a wheel with a different offset.
Old Feb 1, 2025 | 11:25 PM
ilove190evo's Avatar
2000 E320
Make sure you are within the stock stock diameter tire/rim combo. Otherwise, your speedo won't be accurate. How bad? That's all depending on your wheel/tire size combo.
Also, that means your ABS will function differently because the computer think you're going xx mph due to different diameter. May affect trans shift as well, but I can't confirm this.
