W210 suspension system
Old Sep 29, 2020 | 02:59 AM
Novruz Pasazade's Avatar
W210 2000
Hi.You see in the photo, is it possible to replace the arm with one in another car? I want to wear big and wide tires. Do not rub against the bolt.
Old Sep 29, 2020 | 03:24 PM
illest's Avatar
w210 AMG or S213
how wide?
It will probably be easier to roll/pull the fenders to get more space in the front.
Old Sep 29, 2020 | 11:01 PM
W210 2000
Originally Posted by illest
how wide?
I do not want to make changes from the outside. I want to make change the suspension system if possible. If the bolt is higher, the 265 will settle, I think.
Old Oct 1, 2020 | 08:34 PM
nelbur's Avatar
1997 E300D
That bolt is the upper ball joint. The suspension piece it attaches to is the steering knuckle, in the US. It is called called the upright in Europe. The wheel spindle and lower ball joint are attached near the bottom and the steering arm is also attached. I would be surprised if there is a taller replacement.
