Wheel lug size for W210
Old Aug 23, 2004 | 12:09 PM
chan168's Avatar
97 Black E420 W210
I want to get wheel locks for my car. Can somebody tell me what's the lug size? Saw in eBay for 12x1.5 and 14x1.5. <-- Not sure if it going to fit.
Wheel Locks 12x1.5
Wheel Locks 14x1.5
Old Aug 23, 2004 | 12:41 PM
Whitey's Avatar
98 W210 Advantgarde
It is 12mm but if you're using OEM wheels, the lug seat is wrong on those, DO NOT USE THEM!!!!! (see pic, it should be rounded):
Old Aug 23, 2004 | 12:53 PM
chan168's Avatar
97 Black E420 W210
Whitey, yes I am using stock rims. The pic said 17mm?
Old Aug 23, 2004 | 01:43 PM
Whitey's Avatar
98 W210 Advantgarde
17mm head.
Old Aug 23, 2004 | 06:15 PM
E-Klasse's Avatar
W205 C300
Make sure they have a ball seat and not a cone seat. You will need longer thread that the first picture shown. The bolt needs to turn 6 times before it snugs down. any more turns, the bolt is too long and will come out the back side of the rotor and hit the emergency brake in the back. Less that 6 turns will be to short to safely hold the wheel on. Make sure the tread length is 1.5 inches. Don't confuse this with the total bolt length. You can get different head lengths too.
Old Aug 23, 2004 | 09:37 PM
persianb28's Avatar
Do any of you guys know of a website that sells lockings lugs? None of the ones off ebay match the specs you guys recommended.
b
Old Aug 23, 2004 | 10:19 PM
Whitey's Avatar
98 W210 Advantgarde
Hey E, is it me or does that lug seat looks a little flatter, a bit like the 14mm ones?
Old Aug 23, 2004 | 11:01 PM
E-Klasse's Avatar
W205 C300
I was told that the ball seat radius is the same on the 12mm and the 14mm because the head size is 17mm on both. Only the threaded part is a smaller diameter.
** Note: If wheel spacers are used, add that thickness to the bolt length.
Old Aug 23, 2004 | 11:13 PM
Whitey's Avatar
98 W210 Advantgarde
You might recall, I'd posted a picture earlier comparing the two, the 14mm one is definitely flatter (but still a ball joint) - which is the reason why W211 and S-Class wheels are dangerous (in addition to the larger holes). Let me try to find it again.....
Old Aug 24, 2004 | 12:45 PM
kicker's Avatar
E320 2000 w/GPS
b
Try http://www.pure-motorsport.com/
I think they carry both lock bolts and lug bolts.
Old Aug 24, 2004 | 01:13 PM
Whitey's Avatar
98 W210 Advantgarde
Yep E, the radius may be the same but the contact surface is sure different....the reason why using a 12mm bolt on a 14mm wheel will be very weak (the longer tapered end of the ball of the 12mm bolt will prevent the wider part from biting into the curve of the wheel) - check this out, 12mm on the right and 14mm on the left:
Old Aug 24, 2004 | 07:35 PM
persianb28's Avatar
Well I found these on the website:
http://www.pure-motorsport.com/produ...98/CA=50/PA=10
SKU #2145 is what I need right?
Ben
Old Aug 24, 2004 | 09:01 PM
kicker's Avatar
E320 2000 w/GPS
Ben
yeap, that looks right, 39mm thread length. What kind of wheels are you gonna to bolt locked on?
Old Aug 25, 2004 | 02:34 PM
persianb28's Avatar
I have 18's Lowenhart Ld1. Without a garage to park in while at college, I hope this wheel locks will keep my wheels from being stolen.
Old Aug 25, 2004 | 02:51 PM
Whitey's Avatar
98 W210 Advantgarde
Beware different wheels (offset and brand) have different thread/bolt length, as well as bolt seat requirements.........best to pull out one of the current ones to look and measure, just my humble $0.02
Old Aug 26, 2004 | 06:24 PM
marcmayer's Avatar
2020 AMG GTC, 2014 E63S
Brabus and Stock Bolts
Just bought a set of used chrome Brabus Monoblock IVs for my e430 (18x8.5 5x112 offset=35) and they didn't come with bolts. Was planning on just using the stock bolts until I can find some chome ones - until I read this thread.
1. Anybody know if these are ball or cone seats? Can you tell by just looking?
2. Anybody know a source for Chrome lug bolts?
