E420 "limp mode"
After that I've gone crazy, first I bought a dip-stick and checked the fluid level which was a little high. Sucked out about a litre, but didn't help. Then I bought a kit on ebay.de with a new conductor plate, connector, filter and 7 litres of Dexron VI, changed it all, but still the same. Next I bought a iCarsoft MB 2.0 and 38-pin connector, got 13 fault codes saying stuff like Y66/1 reversing/parking lock solenoid short circuit, PWM solenoid valve intermittent fail etc. Cleared all the fault codes but still stuck in 2nd gear. Then I read a post online, and disconnected the battery and put + lead on - terminal for 30 seconds to reset. I've also tried the "key, kick-down 10 sec's, key off, release kick-down, wait 2 min's" procedure. No luck...
What's next, change more stuff? Take it to a MB authorised workshop who can clear the limpmode?
A hydraulic or mechanical issue will clear with a key on/off. Not so for an electrical fault.
