W210 M112 Fuel Injector Power
When starting all is good, but after a few seconds, cylinder 3 shuts off. I have tried with a test light to the injector plug, it blinks as it should for a few seconds, but then goes off. I have also tried to connect a fuel injector to the plug, clicks fine for a few seconds, then shuts down.
Connection to ECU is checked and good.
DTCs found:
P0203 (Y62y3 cylinder 3 fuel injector) - MIL on & current
P0300-80 (Misfire cylinder 4) - MIL on & stored & current
P0304-82 (Misfire cylinder 4) - MIL on & current
P0303-83 (misfire cylinder 3) - MIL on & stored & current
P0303-67 (Misfire cylinder 3) - current
P0304-69 (Misfire cylinder 4) - current
All spark plugs and coils were replaced about 2,000 km ago.
I hope it doesn't require a new ECU.
However, I believe ECU swapping will not work - only a new virgin from MB dealer will. Do you have any experience to suggest it would be possible to simply swap ECU with same part number?
