HELP WITH DASHCAM WIRING
Old Jul 4, 2021 | 09:37 PM
092u-0j2dk's Avatar
W210 E300 Superturbodiesel
SOLVED
I will make an update about this tomorrow for others who would like to know how to install a dashcam or anything else.
Main issues I see are with having the correct ground.
Old Jul 5, 2021 | 11:49 AM
raymond g-'s Avatar
99 E320
looking forward to your write up so I can do it soon. r-
Old Jul 5, 2021 | 03:57 PM
092u-0j2dk's Avatar
The most important thing is making sure you have a strong and proper ground. Here I used the flat pronged piece that came with my fuse splitter kit, and I grounded to the chassis on the 13mm or 14mm bolt here behind the panel for fuses on the dash. The panel can be remove using a flathead screwdriver.
Here is the fuse splitter I used. I tested fuse slots and found an empty one that is normally used for parking sensors (number 14). It shows 11.5 volts with key on and after 30 seconds goes to 12 volts (you will hear like a metal thud in the engine bay) and thus turns on the camera. I put a 15 amp fuse in the bottom (closest to the socket) and 5 amp on the top (you can use any other amp fuse but it MUST be less than 15).
Here is a better look at which socket I plugged it into.
I snipped the end of this rubber piece with some wire cutters and ran the wire through it and then through the firewall. You can access that hole in the firewall by unclipping the panel under the dash in the driver's footwell (there is a rubber grommet in the hole, be careful not to drop the grommet under the fuse box, it will pop out if not careful).
The top piece of this fuse box can be popped off, so that you can slide out that rubber exit piece for the wire. To remove it you need to remove these 6 screws marked in red. (If you can get the wire through without popping off the top, go ahead. But this is a 100% sure way of doing it.
Old Jul 5, 2021 | 04:02 PM
092u-0j2dk's Avatar
Tags: Hard wire dashcam into W210 without cigar lighter fuse. How to run a wire from fuse box in engine bay W210. How to hard wire a radar detector into W210.
Old Jul 5, 2021 | 04:14 PM
092u-0j2dk's Avatar
You can tuck the wire into here
The wire can run through this path and tuck it behind the A-pillar panel.
You can tuck the wire up into the headliner
Old Jul 6, 2021 | 10:24 AM
MBNaveczna's Avatar
E420
Thanks for your help
Old Jul 6, 2021 | 10:26 AM
092u-0j2dk's Avatar
Update: For those who already have a fuse for parking sensors. Someone with an E55 said they are using this fuse right here on the panel on the side of the dash.
