97 E320 Climate Control Question
Old Oct 1, 2004 | 03:47 PM
necompressor's Avatar
Hello, my 97 e320 ac/heater fan seems to only blow air at one speed. Am I correct in assuming it's probably the resistor? If so,how much of a pain in the you know what is it to change out? Is there a procedure listed anywhere? Thanks
Old Mar 11, 2005 | 07:38 PM
thecoopdog's Avatar
1997 mercedes E320, W210 Body
Climate Control blower blows at only one speed.
Did you ever find out what the problem was? Help. Thanks.
Old Mar 12, 2005 | 08:46 AM
mbtech75ny's Avatar
most likely its the blower motor regulator. its not hard to do. you have to remove the underdash panel on pass side. you will see the box where the blower motor lives. there should be a bunch of t20 torx screws holding the cover on, remove and there it is.
