E320 engine knock after egr valve replacement
I put it all together with the new egr, and I started the car. But a knocking noise appeared. Using a mechanics stethoscope, it seems like it's coming from the back of the engine. I took off the new egr and replaced it with my old one, and it still makes the knocking noise. The noise ticks faster as the RPMs go higher.
I don't understand what happened. I was very careful to clean the intake tube to make sure there was no debris in it, and I tried covering any exposed holes that debris can get in. The only thing I can think of is that some debris got either into the intake tube or the fuel injector area.
Anyone have an idea what the cause could be? Is there anything I can do to figure it out without having to tow it to a shop?
Here's some video I made to demonstrate the noise.
https://youtu.be/v9utLF6r4C0
Car: 2001 E320 base sedan
