Warning Lights After Battery Disconnect?
Old Aug 23, 2022 | 10:16 AM
Teutonic_Driver's Avatar
E320 4matic
Disconnected/reconnected my battery several times while doing body work this weekend. When I finally reconnected it upon completion of repairs, I was met with BAS and ESP warning lights upon start-up. I drove the vehicle very briefly and they remained on. I turned it off and then back on again thinking the system would reset. It didn't. Same warning lights.
I shut it off and parked it. My son took it to the store shortly thereafter. A short hop trip of a few miles. This morning: no lights.
Is this normal behavior? It takes the car a few miles to reset the systems? Just curious.
Old Aug 23, 2022 | 12:32 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Whenever the battery is disconnected you must reset the steering wheel angle sensor. You do this by turning the steering wheel lock to lock a couple of times. That resets the sensor parameters and the ESP lights will go out.
Old Aug 23, 2022 | 02:37 PM
E320 4matic
@bbirdwell Hey thanks! I didn't know that.
